V70II D5 ABS klaida, daviklių varža | Stabdžiai | 4 | 2021-10-22, 22:44 |
Klaida EFI -716 | Volvo 850, S/V70, C70 | 3 | 2019-10-20, 08:28 |
Airbag klaida..... | Elektra | 5 | 2019-06-21, 13:30 |
kaip istrinti klaida jei ja meta ne visada | Klaidų kodai ir pranešimai | 7 | 2019-05-14, 20:03 |
Gal kas susidūrė su klaida p2080? | Įvairios tech. diskusijos | 2 | 2018-06-12, 12:37 |
KLAIDA: ECM-0036
Klaida: ECM-0036
Egida |
Написано 2008-12-22, 18:06
![]() Город: Vilnius Сообщения: 65 Вступил: 2008-11-30 |
Sveiki, gal kas yra susidure su 0036 klaida? Turiu jos aprasyma, tik va anglu kalba
![]() DIAGNOSTIK TROUBLE CODE INFORMATION Condition The purpose of this trouble code is only to inform that one or more trouble code exist in the automatic gearbox control unit or in the central electronic module. If these control units request that the engine control module should turn the malfunction indicator lamp on, trouble code ECM-0036 will be set in the engine control module. possible source one or more trouble codes are registered in the automatic gearbox control unit or in the central alectronic module Fault syptom[s] varies wiht the set trouble code Редагировал Apeiron 2010-11-02, 21:55 ----- Volvo S80 2.5 TD 99m |
romas |
Написано 2008-12-22, 18:14
Город: Kopenhaga DK Сообщения: 2029 Вступил: 2007-03-13 |
Cia codas "pasako" kad dezes kompe yra uzregistruotu klaidu. Skaityk dezes klaidas.
Egida |
Написано 2008-12-31, 12:55
na radau nete kazka, bet kaip cia su deze nieko bendra :|
List of errors for: ECU ECM with code 0036 ECM-0036 Rear heated oxygen sensor (HO2S), bank 1 heating. Faulty signal ECM-0036 Bakre lambdasond, bank 1 v?¤rmning. Felaktig signal ECM-0036 Felkod i annan styrenhet ----- Volvo S80 2.5 TD 99m |
romas |
Написано 2008-12-31, 13:06
Vadis raso "Uzregistruota klaida kitame bloke"
Is kur tu paemei sita nzn, gal cia benzo klaidos. Patikrinsim. ----- |
Egida |
Написано 2008-12-31, 13:09
cia radau
![]() ----- Volvo S80 2.5 TD 99m |
romas |
Написано 2008-12-31, 13:29
Nerandu tokiu ir ant benzo, bet pas tave dyz. pagal parasa ir liamdu neturi buti
Egida |
Написано 2008-12-31, 13:39
Romas parašė: Nerandu tokiu ir ant benzo, bet pas tave dyz. pagal parasa ir liamdu neturi buti na bet yra lemda :| ----- Volvo S80 2.5 TD 99m |
Egida |
Написано 2008-12-31, 13:43
sergefino parašė: Zinau ta klaida. Paziurek degimo kampa. na teko man reguliuoti degimo kampa, tai visai kita klaida mesdavo. Reguliavau daugiau nei pries puse metu, per ta laikotarpi buvo viena karta uzsidege, tai uzgesinau varikli ir vel uzvedziau ir ji dingo. ----- Volvo S80 2.5 TD 99m |
romas |
Написано 2008-12-31, 14:01
Isvis nebeaisku. Jei klaida uzgeso, ko tu ieskai.
Egida |
Написано 2008-12-31, 14:06
na uzgeso klaida ta kuri dege del degimo kampo, o sita (kaip suprantu ECM-0036) dar vis dega
перескочить в форум: |
