Beda su elektra s80 | Elektra | 19 | 2019-07-25, 17:12 |
v70 2001 elektra. | Elektra | 2 | 2018-09-05, 09:55 |
Dingsta elektra kišant/ištraukiant raktelį | Elektra | 4 | 2016-09-17, 18:59 |
V70 1kartos 2.5TDI 103Kw Kuro siurblio elektra | Variklis | 3 | 2016-01-04, 18:59 |
elektra, reles ir saugikliai ar taip ir turi būti? | Elektra | 16 | 2015-05-27, 21:31 |
S80 elektra
Parašyta 2011-08-05, 16:13
Gal kas nors turintis VADIS ar VIDA gali įkelti klaidų UEM-0004 ir UEM-0005 aprašymus?
Parašyta 2011-08-05, 18:02
Čiopa, ar be vertimo bus aišku?
372: UEM-0004 Siren. Communication fault Diagnostic trouble code (DTC) information: 1.Condition: If control module recievs no response from siren at repeated requests, this is understood as a communication fault and the diagnostic trouble code (DTC) is stored. 2.Substitute value: None. 3.Possible source: - Open-circuit on UEM_K3 (serial cable between UEM, siren and sun roof). - UEM_K3 short-circuit to ground. - UEM_K3 short-circuit to battery voltage. - Defect siren. 4.Fault symptom[s]: - Siren does not work. - Alarm does not work. 372: UEM-0005 Sunroof. Communication fault Diagnostic trouble code information: 1.Condition: If the control unit does not get a response from the sunroof after a repeated request, the control unit interprets this as a communication fault and a diagnostic trouble code is set. 2.Substitute value: Nothing. 3.Possible source: - Open circuit on UEM_K3 (serial wire between UEM, siren and sunroof). - UEM_K3 short circuited to ground. - UEM_K3 short circuited to voltage supply. - Defective sunroof. 4.Fault symptom[s]: Electric sunroof does not work. ----- Volvo XC70 D5 Auto '06 Volvo 480 S 2,0 Mech '93 Volvo 240 B230F Auto '87 Volvo 480 ES 1,7 Mech '91 Volvo 740 B234F Mech '88 Volvo 740 B200E Mech '89 ----- "Cars are driven by people. The guiding principle behind everything we make at Volvo therefore is, and must remain, Safety." Assar Gabrielsson. A Volvo founder. 1927 |
Parašyta 2011-08-05, 18:16
Dėkui. Panašu, kad reikia ieškoti kas tas UEM_K3
aaaandruna |
Parašyta 2011-08-06, 01:51
keisk po sparnu sirena , ir dings bedos
----- norai s80 d5 ----- Kompiuterine diagnostika. Visoms masinoms DICE , LAUNCH X-431 ,VAG-COM, STAR DIAGNOSIS, OP-COM . KAUNAS aandruna@gmail.com +37062035434-omnitel |
Parašyta 2011-08-06, 13:20
aaaandruna @ 2011-08-06, 01:51 rašė: keisk po sparnu sirena , ir dings bedos Turėjau tokią mintį, nes ir borto kompas dažnai siūlo remontuoti signalizaciją... Bet keisčiausia, kad tai susiję su stoglangiu ----- Volvo S80 D5 '03 AW55-50 ex. Volvo S80 2.5D '99 AW50-42 ex. Volvo S80 T5 '99 M56 ex. Saab 9-3 2.2tid '03 ex. Volvo XC70 D5 '02 AW55-50 ex. Volvo S40 1.8 '97 ----- |
Artas |
Parašyta 2011-08-06, 15:18
net labai susijusi sirena su stoglangio valdymu.
----- Vilnius |
Parašyta 2011-08-08, 22:15
Gal kasnors žinot, ar uždegimo ritės nuo T6 variklio tinka 2,0 T5 varikliui? Po variklio plovimo prieš TA dvi nusibaigė
PauliusD |
Parašyta 2011-08-08, 22:24
Čiopa @ 2011-08-08, 22:15 rašė: Gal kasnors žinot, ar uždegimo ritės nuo T6 variklio tinka 2,0 T5 varikliui? Po variklio plovimo prieš TA dvi nusibaigė tinka, jos visos vienodos ----- Volvo s60 D5, 01 m. ----- Ardau s60, s80, v 70 II, xc70 II dalimis. DIagnostika su VOLVO DICE |
Parašyta 2011-08-08, 22:36
Aišku. Dėkui
Parašyta 2011-08-11, 18:01
aaaandruna @ 2011-08-06, 01:51 rašė: keisk po sparnu sirena , ir dings bedos Pakeičiau, liukas veikia ----- Volvo S80 D5 '03 AW55-50 ex. Volvo S80 2.5D '99 AW50-42 ex. Volvo S80 T5 '99 M56 ex. Saab 9-3 2.2tid '03 ex. Volvo XC70 D5 '02 AW55-50 ex. Volvo S40 1.8 '97 ----- |
aaaandruna |
Parašyta 2011-08-11, 19:23
Čiopa @ 2011-08-11, 18:01 rašė: aaaandruna @ 2011-08-06, 01:51 rašė: keisk po sparnu sirena , ir dings bedos Pakeičiau, liukas veikia ok ----- norai s80 d5 ----- Kompiuterine diagnostika. Visoms masinoms DICE , LAUNCH X-431 ,VAG-COM, STAR DIAGNOSIS, OP-COM . KAUNAS aandruna@gmail.com +37062035434-omnitel |
Parašyta 2011-08-11, 22:49
Reikalai su stoglangiu dar nesibaigė... Pasirodo jis veikia tik į vieną pusę - tik atsidaro. Jeigu nori uždaryti reikia pasirinkti kitą atidarymo būdą, tik taip jis grįžta į uždarytą padėtį. Kol kas vienintelė mintis, kad stoglangio moduliui nusimušo galinės padėtys. Bet kaip jas nustatyti iš naujo? Any ideas?
Tiesa, bandžiau perkrauti kompus atjungdamas akumuliatorių. Nepadėjo Redagavo Čiopa 2011-08-11, 22:51 ----- Volvo S80 D5 '03 AW55-50 ex. Volvo S80 2.5D '99 AW50-42 ex. Volvo S80 T5 '99 M56 ex. Saab 9-3 2.2tid '03 ex. Volvo XC70 D5 '02 AW55-50 ex. Volvo S40 1.8 '97 ----- |
Parašyta 2012-04-05, 15:32
Šiandien apturėjau pakankamai įdomų atvejį su S80 2,5D . Lašelis ryte išvažiavo į darbą, viskas buvo gerai, atsirakino, užsivedė, viskas veikė. Po kurio laiko reikėjo vėl važiuoti. Bandant atrakinti su pulteliu, atsirakino tik galinės durelės , priekinės liko užrakintos. Patraukus už rankenėlės iš vidaus durų kaištukai atšoko, bet durelės neatsidarė . Tuo pačiu neveikė posūkiai, šviesų perjungimas, borto kompo parodymai nepersijunginėjo, neveikė priekinių durelių elektriniai langai . Dureles pavyko atrakinti su rakteliu . Bandant tikrinti saugiklius ir kišant antgal centrinio modulio saugiklį sudirbo durelių "dead lock'ai" . Durelių užrakinimas - atrakinimas pradėjo veikti, bet kitkas liko kaip buvę. Tada nuėmiau minusinę klemą nuo akumuliatoriaus ir pastatęs raktelį ant II padėties užjungiau atgal. Viskas atsigavo .
Vat tokia šiek tiek mistinė istorija , gal kažkam bus naudinga perskaityti . ----- Volvo S80 D5 '03 AW55-50 ex. Volvo S80 2.5D '99 AW50-42 ex. Volvo S80 T5 '99 M56 ex. Saab 9-3 2.2tid '03 ex. Volvo XC70 D5 '02 AW55-50 ex. Volvo S40 1.8 '97 ----- |
Parašyta 2012-05-24, 14:05
Yra bėda, neveikia S80 2,5D ABS'as. Rudenį būdavo tik retkarčiais užsidegdavo ABS lemputė, bet vis dažnėjo, o dabar jau nebeužgęsta . Nuskaičiau klaidas, rado tik vieną "ABS-0070 Pump motor. Faulty signal". Pasiskaičius internete visur siūloma keisti visą ABS bloką, nors klaida rodytų lyg ir tik į varikliuką. Gal kas esate susidūręs? Ar yra įmanoma pakeisti tik varikliuką?
Beje, gal kas turite pasiūlyti visą ABS bloką (be STC)? Kokios jų kainos dabar? ----- Volvo S80 D5 '03 AW55-50 ex. Volvo S80 2.5D '99 AW50-42 ex. Volvo S80 T5 '99 M56 ex. Saab 9-3 2.2tid '03 ex. Volvo XC70 D5 '02 AW55-50 ex. Volvo S40 1.8 '97 ----- |
PauliusD |
Parašyta 2012-05-24, 14:09
Turiu bloka, siaip imanoma ir varikliuka pakeisti. tvarkiau zmogui ta pacia beda, tai, kad nekeist viso bloko ir vamzdeliu, kad nereiktu atsukinet, idejau varikliuka tik. Tik, kad nelabai kas nores parduoti atskirai. Jei bloko reikia kreipkis asmeniskai. Sutarsim kazka
Stulpas |
Parašyta 2012-05-24, 20:23
Čiopa @ 2012-05-24, 14:05 rašė: Yra bėda, neveikia S80 2,5D ABS'as. Rudenį būdavo tik retkarčiais užsidegdavo ABS lemputė, bet vis dažnėjo, o dabar jau nebeužgęsta . Nuskaičiau klaidas, rado tik vieną "ABS-0070 Pump motor. Faulty signal". Pasiskaičius internete visur siūloma keisti visą ABS bloką, nors klaida rodytų lyg ir tik į varikliuką. Gal kas esate susidūręs? Ar yra įmanoma pakeisti tik varikliuką? Beje, gal kas turite pasiūlyti visą ABS bloką (be STC)? Kokios jų kainos dabar? tai tau tik abs bloka keist reikia ,klaida rodo variklio ,bet parejas bus pats blokas ,keist nebutina galima ji pailtuot,cia bus tapati beda kaip ir pas 850 kur "salta paike nueina" ----- |
Parašyta 2012-05-25, 08:57
Aš taip pat įtariu, kad problema gali būti kontaktuose... Turėjau tą pačią bėdą su S80 T5. Bet ten žymiai sunkesnis atvejis buvo, su kitokiais požymiais. Degdavo krūva lempučių, nerodydavo greičio, neskaičiuodavo kilometrų. Litavau gal tris kartus, kol nusispjoviau ir nuspirkau kitą bloką .
Cheezzz |
Parašyta 2012-05-25, 12:10
Miestas: Klaipeda Pranešimai: 3 Įstojo: 2012-05-24 |
Sveiki, nekuriant naujos temos del smulkmenos.. Kokia funkcija atlieka bagazineje esantis oranzinis mygtukas? netoli vietos kur tel kortele dedasi
----- Volvo S80 '00 2.5 TDI ----- |
Parašyta 2012-05-26, 12:10
Vis dėl to problema buvo ABS elektroniniame bloke. Patikrinau varikliuką, jis veikia. Tada atidariau elektroninį bloką ir ten radau akivaizdžiai atšokusį vieną lituotą kontaktą, per kurį užmaitinamas varikliukas. Sulitavau, surinkau - ABS veikia .
