Field 'online_resolution' doesn't have a default value S80 elektra | 5 puslapis | AutoVikingai.lt - Volvo ir Saab - švediškų automobilių klubas ir forumas
S80 ELEKTRA
S80 elektra
#81 Spausdinti pranešimus
Parašyta 2011-08-05, 16:13
Gal kas nors turintis VADIS ar VIDA gali įkelti klaidų UEM-0004 ir UEM-0005 aprašymus?
#82 Spausdinti pranešimus
Parašyta 2011-08-05, 18:02
Čiopa, ar be vertimo bus aišku?
372: UEM-0004 Siren. Communication fault
Diagnostic trouble code (DTC) information:
1.Condition:
If control module recievs no response from siren at repeated requests, this is understood as a communication fault and the diagnostic trouble code (DTC) is stored.
2.Substitute value:
None.
3.Possible source:
- Open-circuit on UEM_K3 (serial cable between UEM, siren and sun roof).
- UEM_K3 short-circuit to ground.
- UEM_K3 short-circuit to battery voltage.
- Defect siren.
4.Fault symptom[s]:
- Siren does not work.
- Alarm does not work.
372: UEM-0005 Sunroof. Communication fault
Diagnostic trouble code information:
1.Condition:
If the control unit does not get a response from the sunroof after a repeated request, the control unit interprets this as a communication fault and a diagnostic trouble code is set.
2.Substitute value:
Nothing.
3.Possible source:
- Open circuit on UEM_K3 (serial wire between UEM, siren and sunroof).
- UEM_K3 short circuited to ground.
- UEM_K3 short circuited to voltage supply.
- Defective sunroof.
4.Fault symptom[s]:
Electric sunroof does not work.
Volvo V60CC B5 Auto '22
ex Volvo XC70 D5 Auto '06
ex Volvo 740 B234F Mech '88
#83 Spausdinti pranešimus
Parašyta 2011-08-05, 18:16
Dėkui. Panašu, kad reikia ieškoti kas tas UEM_K3 Frown
aaaandruna
#84 Spausdinti pranešimus
Parašyta 2011-08-06, 01:51
Miestas: kaunas
Pranešimai: 133
Įstojo: 2010-11-08
keisk po sparnu sirena , ir dings bedos Frown
norai s80 d5
DICE , LAUNCH X-431 ,VAG-COM,
STAR DIAGNOSIS, OP-COM .
KAUNAS aandruna@gmail.com
+37062035434-omnitel
#85 Spausdinti pranešimus
Parašyta 2011-08-06, 13:20
aaaandruna @ 2011-08-06, 01:51 rašė:
Turėjau tokią mintį, nes ir borto kompas dažnai siūlo remontuoti signalizaciją... Bet keisčiausia, kad tai susiję su stoglangiu Frown
Artas
#86 Spausdinti pranešimus
Parašyta 2011-08-06, 15:18
Pranešimai: 609
Įstojo: 2007-03-10
net labai susijusi sirena su stoglangio valdymu.
Vilnius
#87 Spausdinti pranešimus
Parašyta 2011-08-08, 22:15
Gal kasnors žinot, ar uždegimo ritės nuo T6 variklio tinka 2,0 T5 varikliui? Po variklio plovimo prieš TA dvi nusibaigė eusa
PauliusD
#88 Spausdinti pranešimus
Parašyta 2011-08-08, 22:24
Miestas: Ukmerge
Pranešimai: 346
Įstojo: 2009-07-14
Čiopa @ 2011-08-08, 22:15 rašė:
tinka, jos visos vienodos
Volvo s60 D5, 01 m.
DIagnostika su VOLVO DICE
#89 Spausdinti pranešimus
Parašyta 2011-08-08, 22:36
Aišku. Dėkui Smile
#90 Spausdinti pranešimus
Parašyta 2011-08-11, 18:01
Pakeičiau, liukas veikia Grin
aaaandruna
#91 Spausdinti pranešimus
Parašyta 2011-08-11, 19:23
Miestas: kaunas
Pranešimai: 133
Įstojo: 2010-11-08
Čiopa @ 2011-08-11, 18:01 rašė:
okCool
norai s80 d5
#92 Spausdinti pranešimus
Parašyta 2011-08-11, 22:49
Reikalai su stoglangiu dar nesibaigė... Pasirodo jis veikia tik į vieną pusę - tik atsidaro. Jeigu nori uždaryti reikia pasirinkti kitą atidarymo būdą, tik taip jis grįžta į uždarytą padėtį. Kol kas vienintelė mintis, kad stoglangio moduliui nusimušo galinės padėtys. Bet kaip jas nustatyti iš naujo? Any ideas? Frown
Tiesa, bandžiau perkrauti kompus atjungdamas akumuliatorių. Nepadėjo Crying
Redagavo Čiopa 2011-08-11, 22:51
#93 Spausdinti pranešimus
Parašyta 2012-04-05, 15:32
Šiandien apturėjau pakankamai įdomų atvejį su S80 2,5D Smile. Lašelis ryte išvažiavo į darbą, viskas buvo gerai, atsirakino, užsivedė, viskas veikė. Po kurio laiko reikėjo vėl važiuoti. Bandant atrakinti su pulteliu, atsirakino tik galinės durelės Grin, priekinės liko užrakintos. Patraukus už rankenėlės iš vidaus durų kaištukai atšoko, bet durelės neatsidarė Smile. Tuo pačiu neveikė posūkiai, šviesų perjungimas, borto kompo parodymai nepersijunginėjo, neveikė priekinių durelių elektriniai langai Smile. Dureles pavyko atrakinti su rakteliu Smile. Bandant tikrinti saugiklius ir kišant antgal centrinio modulio saugiklį sudirbo durelių "dead lock'ai" Smile. Durelių užrakinimas - atrakinimas pradėjo veikti, bet kitkas liko kaip buvę. Tada nuėmiau minusinę klemą nuo akumuliatoriaus ir pastatęs raktelį ant II padėties užjungiau atgal. Viskas atsigavo ura.
Vat tokia šiek tiek mistinė istorija Grin, gal kažkam bus naudinga perskaityti Smile.
#94 Spausdinti pranešimus
Parašyta 2012-05-24, 14:05
Yra bėda, neveikia S80 2,5D ABS'as. Rudenį būdavo tik retkarčiais užsidegdavo ABS lemputė, bet vis dažnėjo, o dabar jau nebeužgęsta Smile. Nuskaičiau klaidas, rado tik vieną "ABS-0070 Pump motor. Faulty signal". Pasiskaičius internete visur siūloma keisti visą ABS bloką, nors klaida rodytų lyg ir tik į varikliuką. Gal kas esate susidūręs? Ar yra įmanoma pakeisti tik varikliuką?
Beje, gal kas turite pasiūlyti visą ABS bloką (be STC)? Kokios jų kainos dabar?
PauliusD
#95 Spausdinti pranešimus
Parašyta 2012-05-24, 14:09
Miestas: Ukmerge
Pranešimai: 346
Įstojo: 2009-07-14
Turiu bloka, siaip imanoma ir varikliuka pakeisti. tvarkiau zmogui ta pacia beda, tai, kad nekeist viso bloko ir vamzdeliu, kad nereiktu atsukinet, idejau varikliuka tik. Tik, kad nelabai kas nores parduoti atskirai. Jei bloko reikia kreipkis asmeniskai. Sutarsim kazka Smile
Volvo s60 D5, 01 m.
Stulpas
#96 Spausdinti pranešimus
Parašyta 2012-05-24, 20:23
Pranešimai: 1756
Įstojo: 2007-03-14
Čiopa @ 2012-05-24, 14:05 rašė:
tai tau tik abs bloka keist reikia ,klaida rodo variklio ,bet parejas bus pats blokas ,keist nebutina galima ji pailtuot,cia bus tapati beda kaip ir pas 850 kur "salta paike nueina"
#97 Spausdinti pranešimus
Parašyta 2012-05-25, 08:57
Aš taip pat įtariu, kad problema gali būti kontaktuose... Turėjau tą pačią bėdą su S80 T5. Bet ten žymiai sunkesnis atvejis buvo, su kitokiais požymiais. Degdavo krūva lempučių, nerodydavo greičio, neskaičiuodavo kilometrų. Litavau gal tris kartus, kol nusispjoviau ir nuspirkau kitą bloką Smile.
Cheezzz
#98 Spausdinti pranešimus
Parašyta 2012-05-25, 12:10
Miestas: Klaipeda
Pranešimai: 3
Įstojo: 2012-05-24
Sveiki, nekuriant naujos temos del smulkmenos.. Kokia funkcija atlieka bagazineje esantis oranzinis mygtukas? netoli vietos kur tel kortele dedasi
Volvo S80 '00 2.5 TDI
#99 Spausdinti pranešimus
Parašyta 2012-05-26, 12:10
Vis dėl to problema buvo ABS elektroniniame bloke. Patikrinau varikliuką, jis veikia. Tada atidariau elektroninį bloką ir ten radau akivaizdžiai atšokusį vieną lituotą kontaktą, per kurį užmaitinamas varikliukas. Sulitavau, surinkau - ABS veikia Smile.
Beda su elektra s80 Elektra 19 2019-07-25, 17:12
v70 2001 elektra. Elektra 2 2018-09-05, 09:55
Dingsta elektra kišant/ištraukiant raktelį Elektra 4 2016-09-17, 18:59
V70 1kartos 2.5TDI 103Kw Kuro siurblio elektra Variklis 3 2016-01-04, 18:59
elektra, reles ir saugikliai ar taip ir turi būti? Elektra 16 2015-05-27, 21:31
