V40 NEVISAD DIRBA CILINDRAI
V40 nevisad dirba cilindrai
taucislovas
Parašyta 2017-08-07, 22:12
Miestas: Kaunas/Šakiai
Pranešimai: 117
Įstojo: 2017-07-19
Sveiki, yra tokia bedele su v40 2,0 121kw 2001m. Uzkurus salta, pirmas 5s variklis dirba graziai, po to nedirba vienas cilindras. Kai uzsyla, ant duju situacija geresne, o kartais buna, kad labai graziai dirba tiek dujom, tiek benzu. Zvakes, zvaklaidziai- nauji. Babinos keistos, tas pats. Meta tokias klaidas: ECM-16 Front heated oxygen sensor (HO2S) - Signal too low
ECM-44 Missfire, emission level - Faulty signal
ECM-45 Missfire, emission level - Faulty signal
ECM-4D Misfire which damages catalytic converter - faulty signal.
Ar gali taip buti del katalizatoriaus? Maciau jis ispjautas. Lamda buvau keites, bet nesu tikras ar i gera. P.S. Gal kas turite parduoti siai auto salono vemtiliatoriaus valdyma?
Parašyta 2017-08-07, 22:58
Pranešimai: 3804
ECM-44 ir ECM-45 ir ECM-4D galimos priežastys:
- Fuel stoppage
- Repeated cold starting where the engine coolant temperature (ECT) has not reached normal operating temperature between starts.
- Water in the spark plug wells
- Defective spark plugs, ignition cables, ignition coil or flywheel / pulse wheel
- Contaminated fuel or incorrect fuel type
- Blocked / leaking injector
- Intermittent open-circuit, intermittent short-circuit to ground, intermittent short-circuit to voltage supply, contact resistance or loose connection in the ignition system low-tension side, in the injector circuit or fuel pump (FP) circuit
- Blocked crankcase ventilation.
- Damaged VVT-unit.
- Moisture, flashover in the ignition system on HT side
- Leakage between the cooling system and cylinders
- Uneven compression
taucislovas
Parašyta 2017-08-08, 17:12
Pranešimai: 117
Įstojo: 2017-07-19
Nepaminejau, kad iki 1500rpm pan taip buna. Ar degimo mietkes statosi taip pat, kaip pvz s60 t5? Nes perziurejau, sustaciau taip, kaip pas savo s60 statau, situacija tokia pat. Vvt naujas idetas maciau. Smile
Parašyta 2017-08-09, 21:38
Pranešimai: 3804
farm5.staticflickr.com/4439/36070029440_704d4ea4ab_b.jpg
taucislovas
Parašyta 2017-08-09, 23:57
Pranešimai: 117
Įstojo: 2017-07-19
Aciu, Arturai Smile taip ir dariau, mietkes esu 99% isitikines, kad teisingos. Laiko turint bandysiu ieskoti bedu ir pasidalinti rezultatais Smile
Vovlo v50 powershift MPS6 greičių dėžė dirba nesklandžiai Transmisija 1 2020-07-21, 21:37
Sunkiai dirba saltas variklis Variklis 3 2016-09-29, 17:49
Kur dirba AutoVikingai? AutoVikingai 74 2016-03-07, 12:54
S60 valytuvų varikliukas garsiai dirba Elektra 2 2014-10-28, 05:35
Pusukių svirtis - nevisad suveikia Elektra 3 2012-08-11, 21:27
