Field 'online_resolution' doesn't have a default value Volvo v70 D5 2002m. tepalai | AutoVikingai.lt - Volvo ir Saab - švediškų automobilių klubas ir forumas
VOLVO V70 D5 2002M. TEPALAI
Darius
Parašyta 2012-01-02, 18:38
Miestas: Kaunas-Panevezys
Pranešimai: 113
Įstojo: 2010-10-17
Reikia patarimo pasiule tepalus valvoline SynPower MXL 5W-30 ka manote ar jie tinka sitam motorui.
volvo v70 D5 2002 m.
Parašyta 2012-01-02, 18:41
Darius @ 2012-01-02, 18:38 rašė:
Tavo motorui gamintojas rekomenduoja 0w30 arba 0w40. Specifikacijos: ACEA A3-04/B4-04 ; API SM/CF
Darius
Parašyta 2012-01-02, 18:43
Pranešimai: 113
Įstojo: 2010-10-17
bet pagal ju katalogus tai tepalus meta kuriuos nurodziauFrown
Parašyta 2012-01-02, 18:46
Darius @ 2012-01-02, 18:43 rašė:
Cia nebent karstam klimatui, arba tiesiog sis gamintojas negamina 0w30/0w40, todel nurodo artimiausia pagal specifikacijas is savo gamos.
Redagavo Johny 2012-01-02, 18:48
atrabotke
Parašyta 2012-01-03, 11:02
Pranešimai: 27
Įstojo: 2011-03-18
Nufotkinau savo V70 manualą:
img442.imageshack.us/img442/7804/imag0174cv.jpg
Tavo mašinai tepalai turi atitikti ACEA B4 specifikacijas.
S40, 96m, 2.0
V70, 04m, 2.5T
Tomasb
Parašyta 2012-01-03, 11:38
Pranešimai: 91
Įstojo: 2011-11-27
Idomiausia ka reiskia tie ACEA kodukai ?:
pagal ACEA:
A1/B1 Oil intended for use in gasoline and car + light van diesel engines specifically designed to be capable of using
low friction low viscosity oils with a High temperature / High shear rate viscosity of 2.6 to 3.5 mPas.s. These oils may be
unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
A3/B3 Stable, stay-in-grade oil intended for use in high performance gasoline and car + light van diesel engines and/or
for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of low viscosity oils ,
and/or for sever operating conditions as defined by the engine manufacturer.
A3/B4 Stable, stay-in-grade oil intended for use in high performance gasoline and direct injection diesel engines, but
also suitable for applications described under B3.
A5/B5 Stable, stay-in-grade oil intended for use at extended drain intervals in high performance gasoline and car + light
van diesel engines designed to be capable of using low friction low viscosity oils with a High temperature / High shear
rate viscosity of 2.9 to 3.5 mPa.s. These oils may be unsuitable for use in some engines. Consult owner manual or
PVZ mano V70 II D5, 2005metu 136 kW, rekomenduojamas tepalas A5/B5, bet ar istikruju ka lemia tas ACEA, gal yra specu ismananciu?
Jei teisingai supratau tai pvz tas A5/B5 taip vadinamas longlife, su kuriuo gali nuvaziuot 30 tukst. km pries keisdamas?
Jei imetus tiek nenuvaziuoji, tai tada uztenka ir A3/B4, nes ir ta ir ta keisti reikia pagal rekomendacijas ne reciau kaip kas metai? ar ne?
Redagavo Vyskups 2012-01-03, 11:46
Volvo V70 II, 136 kW, 2005, mechanika
atrabotke
Parašyta 2012-01-03, 14:32
Pranešimai: 27
Įstojo: 2011-03-18
Na aš taip giliai nesiruošiu kapstytis Smile
Man tinkantys tepalai turi atitikti ACEA A3 specifikacijas, taigi susiradau 0W-30 už protingą kainą, kurie atitiko šiuos reikalavimus (konkrečiai - TOTAL QUARTZ ENERGY 9000 0W30) ir juos naudoju.
Su "longlaifiniais" keitimo intervalais variklio damušinėti nesiruošiu ir juos keičiu kas 13-15 tukst. km.
S40, 96m, 2.0
V70, 04m, 2.5T
pegas
Parašyta 2013-02-10, 17:33
Pranešimai: 7
Įstojo: 2013-01-19
o man čia dabar klausimas kilo: o kaip jeigu į v70 D5 2002m. susipylus, dabar pakankamai nebrangiai parduodamus, NESTE CITY PRO A5/B5 0W-30? Kilo dėl to, kad aprašyme parašyta - specialiai volvo nuo 2005. Ar čia man kvailas klausimas kilo? Frown
Volvo V70(II) D5 120kw 2002m
www.manogarazas.lt/user_icons/fuel_icon_4_2343.png
Parašyta 2013-02-10, 17:40
Gali pilti, bet intervalas iki 20 000km ir nedaugiau
Parašyta 2013-02-10, 17:41
Tomasb @ 2012-01-03, 11:38 rašė:
pagal ACEA:
A5/B5 jau yra prikaikytas DPF filtrams.
pegas
Parašyta 2013-02-11, 15:26
Pranešimai: 7
Įstojo: 2013-01-19
Johny @ 2013-02-10, 17:40 rašė:
Tada dar vienas klausimėlis: o tarkim galima būtų pilt NESTE OIL CITY PRO 5W-30? Nes kiek žiūrinėjau, daug kur rašo, kad galima naudot ir tokius. Kiek suprantu šitie labiau skirti šiltesniam klimatui. Bet jei tokius dabar susipylus, gi ateina vasara.
Šiaip visada keičiu nuvažiavęs 15k km, čia gaunasi kartą per metus.
Parašyta 2013-02-11, 16:37
Siaip gamintojas rekomenduoja 0w30, 0w40. Supilti galima kad ir 15w40 mineraline alyva, bet kazin, kaip tai atsilieps tavo varikliui...
